zodiac340m
Thread starter- Joined
- Jan 21, 2011
- 226
So how do you turn on an outboard engine? you pull the plug thing, then you bring some choke out and slowly put the choke back right? Then what? you put the boat in neutral before you pull the cord to start it? Or you pull choke first, then cord then put in neutral? Once the engine is started, and its in neutral is the boat moving yet? Then what about reverse, if you put it in reverse but do not rotate the trottle for gas is it moving or just the prop buzzing in the water? Once you are done with all this and you are say coming to the beach area to get out of water, you move forward then to neutral then to reverse? How do you stop the engine completely? And how do you bring the engine up from the water but still stay attached to the transom? Are all engines giving this option to raise the prop from the water?
There are very serious questions ok. thanks
