I have a 30+-year-old 18? CC and the gas tank vent is acting like a pickup tube. If I try blowing into the vent line it has a stop and no air will pass. If I apply a vacuum only fuel comes out through the tube. I?m thinking the tank was built with two pickup tubes; one in front and one in the rear, and one used for a vent.
The barb at the tank fitting is for a 3/8 I.D. hose (a 5/8 I.D. hose is clamped to it).
A problem happened recently when the fuel began belching out the filler tube during the fill, like the check valve in the vent line has gone bad and is partially closed.
If it is a pickup/vent tube gone bad it is going to stay that way and be plugged off, and a new fitting installed (one that will only extend a very short distance into the tank). It would be almost impossible to get a wrench on the existing elbow.
It sounds strange but that is where I am at the moment.
