Hi, I have a 91 Johnson 60hp that I'm trying to get set up on my bass boat. Currently, my fuse block is wired directly to the battery. I want to run this block through the ACC switch on my ignition switch so that nothing can be operated unless the key is in. I'm not sure which wire should run from the switch to the 12v power supply on the fuse block.
The switch has 6 connections.
