acceleration problem
reece3223
today is the first day I have spent all day on the lake. the first tank of gas I had no problems the second tank gave me a worry. The boat started and idled just fine even when i put it in gear at idle speeds. I then accelerated quickly it wheezed and sputtered i then put it back in neutral and revved the motor no sputtering put it back in gear then it worked fine This happened about 5 more times.
I use 91 octane exclusively 93 if i can find it.
Re: wheezed and sputtered
Ayuh,.... Why,..??
You don't say just What We're talkin' 'bout,... But,... Change the Fuel Filters...
Maybe it'll quit Coughing...
reece3223
I will look at the fuel filter although the fuel filter was replaced at the beginning of the season. start simple right.
I forgot to put in the original string 1993 OMC 3.0 cobra
windsors03cobra
Re: acceleration problem
Perhaps a failing accelerator pump in the carburetor or some gunk and grit clogging something in the carb up or the carb just plum needs to be rebuilt.
With the flame arrestor off pump the throttle and listen to hear it squirt gas, should be a good shot of gas down the venturi's.
Low test would probably be fine unless you have a high compression powerhouse......:cool:
