hawk miller
- Joined
- Jul 16, 2009
- 7
My accessories do not work ie horn /running lights /cabin lights/ blower. Have voltage to switches ?
Can you test for power at the horn or lights itself? If power is there must be bad ground.
Eric,
To test for power at any 12V device, one must have a good ground. To check for a bad ground, do a continuity check between the the ground at the device and a known "good" ground...
Also if your battery has been sitting all winter without being charged then it may be badly sulfated.
In this case it can have 12 volts but when you apply a load the voltage will drop way down to the point a light will not light.
Check the Battery connections both positive and the ground as well.
