rolmops
Thread starter- Joined
- Feb 24, 2002
- 5,751
I was told by an outboard repairman that it is a good idea to remove every last bit of aluminum that was on the cylinder walls of a 50 horse evinrude.He said that aluminum leftovers would grind against the new aluminum pistons and wear them down fast.<br />Then he continued to say that he does it by smearing some diluted muriatic acid on the cylinder walls, because aluminum corrodes away very fast and the sleeve does not.After cleaning up the acid he would hone cylinder and it should be ready for a rebuild.<br />The pistons I consider using are "GLM PRODUCTS".Did any of you guys ever hear about those?<br />Any of you ever use this acid cleaning method?<br />Thanks,Rolmops
