Add a Livewell Switch Again
IlliniDoc
Well a couple years ago I wanted to add a livewell switch to the front of my posted on this forum after a few tribulations Sam am I got me on the right track and I got it done. Well I bought a different boat and would like to do the same thing so you would think just follow Sams original instructions dummy right. Well here is my dilemma,the new boat is a 2016 Ranger RT178c with 2 live wells a separate pump for each well and a single timer runs both pumps, the old boat had a single pump and timer so in my mind the wiring would be a little more complex on the new boat. Would like to know if and how I can add an extra switch to the new boat.
Hopefully the pics are self explanatory.
Thanks in advance for your help.FA885B71-6F18-4913-BBF7-42D2804DA39B.jpeg092D3D1B-5A3A-4535-B1F5-2F2311B5E56C.jpeg
IlliniDoc
I neglected to mention I am only interested in adding another switch to the front livewell. Thanks again for any help.
sam am I
Are you able to run a few wires forward from the helm to the bow panel?
IlliniDoc
Good to hear from you again Sam.
I believe I can get wires to the front relatively easily.
sam am I
Thank you, you as well.............So, to keep things as simple as possible and not have you chasing too many odd ball connections and limit bilge diving..........There are probably a few other ways, but I'd add the new bow switch more of less in parallel with the helms switch as follows..........
You'll pick up two (of 5) connections from the bow area as there appears to be a small ground and fused power buss somewhere in the bow you can use.
From that bow buss, a ground will go to pin 7 of your new bow panel switch(use same type switch, 8 pin DPDT lighted) and a fused 12V will go to pins 2 & 4 of the new bow switch.
You'll need to run three wires from the helm switch to the new bow switch, grab the connections right off the helm switch that runs the front pump.....So, 3 to 3, 6 to 6, 5 & 8 to 5 & 8.
For above, see added red wires and the additional switch("2nd Aerator") added in the "Bow Panel" in the schematic below.
Features are ...........When "on" in either mode(auto or man), either switch's selected settings will light the other switch's "on" indicator light(e.g. if helm switch is left on, the bow's switch[even if in the off position] will have its light lit up and vise versa) .............If either switch is in auto, the other switch will over ride it when switched into its "manual" position.(but not the opposite, manual will trump[Sucks!!] auto)
IlliniDoc
Well sir I am in your debt again. It will be a while before I can get back to this project as I have been volunteered for another but I will let you know how it goes.
Again thanks for sharing your knowledge with me.
doc
IlliniDoc
Sam after your reply I was looking for parts to have when I get to this job, can this be done with a 7pin switch? I see you are only using 7 of the 8 pins in your drawing and I can only seem to find 7 pin DPDT lighted switches.
Thanks Doc
sam am I
No worries and yes, let us know please.
doc
You're very welcome
Can this be done with a 7pin switch?
Thanks Doc
Yup, but you'll have to mirror (see revised schematic below) the switch's pinning. This keeps the switch's light functioning as intended (solid on in manual AND cycles w timer in auto).
This assumes that the 7 pin DPDT switch's light (low/gnd side[cathode] if LED) is wired to pin 7 and it's (high/12V side[anode] if LED) are both hard wired to pins 1 and 3.......This is more or less most manu's standard/default config and should work fine.(See second attachment)
  • Screenshot 2022-06-05 at 11-56-25 Amazon.com LED Marine Boat 7 Pins Dpdt On-Off-on Rocker Swit...png
IlliniDoc
You're very welcome
Thanks again Sam sorry to take up your Sunday.
Will follow up with results.
Doc
IlliniDoc
No prob, I wasn't doing squat.......
Sam I have got the wires run and just got the switch. I am taking a pic of the switch pins. They are positioned different than what your schematic shows. Do I mirror your drawing schematic or follow the pin numbers as you have them?
sam am I
I assume the new switch's pins 2 and 5 aren't hard wired together as shown in the manu's picture?
Else yes, just follow the pin numbers as depicted/marked on the new switch and hook the wires up as shown in schematic in post #8
sam am I
No, 2 & 5 of the new switch can't be wired together either internal or external...The switch has to be wired as shown in the schematic post #8
Local two (2) wires at new switches added bow location are...
  1. New switch's pin 5 wired to new switch's pin 1(a jumper if you will), both then wired to +12V in bow buss
  2. New switch's pin 7 wired to ground in bow buss
3 wires you ran are..............
  1. New switch's pin 2 wired to front pump switch's pins 5 & 8(another, but already existing jumper)
  2. New switch's pin 6 wired to front pump switch's pin 3
  3. New switch's pin 3 wired to front pump switch's pins 6
IlliniDoc
Probably not how you want to start your day but I think you have finally got through my ignorance. Hooked up front switch as you drew it pump comes on in both positions ( without water couldn’t test timer) confident it will work. My only other issue is the bottom light on new switch is on no matter which position the switch is in. Scratching head, bad switch I have a wire crossed any ideas?69209C8E-B237-4390-A21E-B429BC67143C.jpeg
sam am I
Lol......It's all good.
I lead you astray, we have to go back in Doc!!
  1. Remove from switch #2 the jumper pins 1 to 5.
  2. Add to switch #2 a jumper from pins 1 to 2 to 4.(See attachments)
Functionality of switch lights are as follows.
With bow switch off position....
  1. Helm switch in manual, helm switch light will be on solid and bow switch top light on solid.
  2. Helm switch on auto, helm switch light will cycle w pump and bow switch top light will cycle with pump.
With helm switch in off position...
  1. Bow switch in manual position, bow switch top light on solid and helm switch light on solid.
  2. Bow switch in auto position, bow switch top AND bottom lights cycles with pump and helm switch light cycles with pump.
BONUS..............Switches off, lights off!!! ;)
IlliniDoc
Well sir with some head scratching and some expertise on your part we have completed another successful install. As I said haven’t put water to it to test the timer but confident it will work
Thanks for all your help and patience. Not sure I will have enough beer to repay.
God Bless and have a great rest of your day.
sam am I
You're quite welcome, couldn't have done it w/o you doing the dirty work ;) The additional switch up front is an awesome idea BTW!
You owe me nothing sir and your thank you is the best re-payment in the world these days.
IlliniDoc
sam am I just wanted to follow up with you regarding the project. Put water to it today no surprise everything works as it should, couldn't have done it without your help.
Thanks again
