Rranger
- Joined
- May 18, 2009
- 464
Adding a Vervor battery isolator to a wiring setup with a perko switch. I'm not sure how to wire the battery isolator in. Not much on the net. Hopefully someone on here knows. Would appreciate hearing.attached is a crude drawing of present system and the vervor wiring diagram. Second question is will be addind a 110V 2 bank 10amp battery tender can I hook to both batteries as normal and will charge when perko switch is off or on?
