adding a carb?
Red9654
i have a chrysler outboard with a mechanical fuel pump that goes to a single carb. is it possible to add a second carb to it and how would i do it?
Silvertip
Honorary Supreme Mariner
Re: adding a carb?
This Chrysler outboard is what HP, what year, and what model -- my crystal ball is broken again so I can't see it. And doing this would solve what? The motor was designed with a single carb for a reason: It doesn't need two nor would it likely run well as twice as much fuel and air is not a good thing. With exhaust tuning and extensive porting the second carb might add a few ponies. But first you would need an intake that supports two carbs and must fit that engine..
Red9654
Re: adding a carb?
its a 1969 45 hp model 4545. and it would solve me doing this just to see what would happen
Frank Acampora
Re: adding a carb?
No, it is not possible to add a carb and in reality, even if you custom made a manifold, you would not get much increased performance. In fact, you just may over-carb the engine and get really poor performance.
I modified a 55 Chrysler to accept a bigger carb and the engine simply would not run well with the added venturi area. It was over-carbed. You can search some of my posts about it on the Force/Chrysler forum. Search for "Say hallo to my leetle frand."
Don't bother wasting your time trying to add a second carb.
ondarvr
Re: adding a carb?
If you are looking for more power buy a bigger motor, sell yours and look for a good deal on something else.
Re: adding a carb?
... in reality, even if you custom made a manifold, you would not get much increased performance. In fact, you just may over-carb the engine and get really poor performance.....
Here's the deal.... To have a good, consistent fuel/air mixture you need to have a certain minimum airflow velocity through the venturi. By adding a second carb you'd be roughly cutting the velocity in each carb in half, which would be a disaster for your fuel/air mixture.
