Adding a larger amp.
The Show
Hello,
I'm looking to add an amp and a sub to my boat. Here is my current setup:
6-6.5 Polk DB651's. I currently have 2 of them running off of a 160 watt amp.
I can let the stereo run for quite awhile. I've never had a dead battery. However, i'm replacing the 160 watt amp with a 660 watt amp and plan to run my 2 tower 6.5's and a 10 inch sub off of this amp.
I don't really have room for another battery. This would be the ideal situation. I'm wondering if anyone has ran an amp this large off of the single battery? I realize I won't be able to leave the stereo on as long as I do now.
Any thoughts/recommendations would be great, thanks.
bruceb58
Re: Adding a larger amp.
As long as you play everything at the same volume as you do now, the only extra load will be the sub.
Slide
Is your current battery a dual purpose deep cycle? I would replace it with one if it's not. You ought to be OK, but subwoofers can be big power hogs. I would keep a jump box on your boat until you've run it a few times and gotten a feel for how long you can play your music.
bruceb58
Don't let your battery get close to being dead. 12.0V is as far as you really want to discharge it.
