madurodave
Thread starter- Joined
- Jul 15, 2009
- 347
Hello iboats. I have been running one battery with no issues all summer. On this one battery I have all the typical stuff being used, plus a stereo, amp and tower speakers. To make a long story short, the last few outings the AMP cuts out. I assume the draw is just too much for this one battery to handle. Plus, I realize the power wire from the amp to the battery is probably just too long. I recently picked up a second battery (deep cycle) and a Perko switch to isolate my engine and starting battery from the toys.
I have a few questions before I tackle this project. Thanks in advance for any guidance and any help you may be able to provide.
Perferred option: I want to place the second battery and the perko switch in the cuddy. Is it ok to have a long run of wire from the front to the back of the boat between batteries and ground to use the switch?
Alternate option 1: I would just place the second battery in the back of the boat but that would mean I would need a long run of wire from the amp to the battery in the back....is this the better option? If so, on a 21'boat, what gauge wire should I use?
Alternate option 2: I would put but both the battery (and switch) and the amp in the back of the boat but I don't know where to locate (or if they are available) the preamp output wires - rca cables from the head unit to the amp?
As you can see, this rookie needs a little help. Thanks so much.
