Adding a Tach?
igh7070
I have a 35hp johnson outboard I would like to add a tach to. Where do I connect the signal wire on the at? Can this be done?
Faztbullet
Re: Adding a Tach?
If it is electric start it may or may not have a charging coil. It depends on how ordered or which starting kit added on. Look for a rectifer on starboard side of engine, it is round half dollar size with yellow and red wires going into it. If you have add your signal wire to the yellow w grey stripe.
