eclark53520
Thread starter- Joined
- Sep 2, 2010
- 174
Re: Adding a Tell Tale question
@ a rated temperature of 220?F...a long time...
If you would've taken the time to read the entire thread, i already mentioned multiple times it's not where the service bulletin says to drill(however, that service bulletin doesn't cover my exact engine...). I also mention that it's safer to drill there and gives you a lot more room to work while performing exactly the same as the suggested location. So what's the difference?
Not the correct place to drill, and how long do you expect that clear plastic hose to last with about water 140F temp?
