Adding a tell tale to a V-4 Crossflow - and call for others
Status
Not open for further replies.
iwombat
Occasionally someone does a search and finds my posts on adding a tell-tale, then PMs me on what to do. I never did get good pictures the first time around. Well, here I am doing it again, so I figured I'd take some pictures for anyone else wanting to do this.
This time it's a '76 85hp, and it has the convenient casting boss on the side of the #1 cylinder.
Procedure:
1. Center punch the boss
2. Drill pilot hole with . . . well something smallish.
3. Enlarge pilot hole with 11/32 bit.
4. Tap with 1/8 pipe tap.
Fit with either a 1/8" threaded bronze nipple, or the OEM fitting.
Pictures of the location ensue.
_brad_
Re: Adding a tell tale
You da man!
iwombat
Re: Adding a tell tale to a V-4 Crossflow - and call for others
Tashasdaddy thought this would make a good FAQ. I would tend to agree IF I can include some other engines besides the v-4 crossflow. Lacking a better place to do so, if you folks have pictures, diagrams, or whatever for some of the other models, especially the 3-cylinders, post them here. I'll see what I can do about putting together a write-up.
Also, what years did OMC start putting tell-tales on particular models?
Willyclay
Great info for us old guys with old motors. Thanks!
tashasdaddy
also the 2 cylinders, like the 50hp. there are so many questions on this.
mrfixitman40
Would this also be a good way of putting a temp sending unit or is the wall to thin??
ezeke
The 50HP, 65HP and 70HP telltales can all be set up according to Service Bulletin 2276. The OEM fittings listed can be used on most engines, including the V4 and v6 models.
I'll put a jpg copy below, but you will have to enlage it with your picture program to read it easily:
iwombat
Thanks, Ezeke.
Still collecting . . .
Does anyone have a good picture of the fitting that goes through the cowling? Preferably w/o hose and w/o the nipple installed. I'd take one myself, but I broke a clip on mine and it's held in with a dollop of 4200. Not the sexiest picture for a FAQ.
Here's where it's living for now.
http://www.combshouse.com/~bob/WaterPressureIndicator.html
Still need info on the inline 2s and some part #s for all the OEM fittings. I'll look 'em up eventually. But if someone already has them handy.
ezeke
Part Number 321885 looks like this:
tashasdaddy
my 93 40 only has the hose going thru, and extending about 2 inches.-+
iwombat
That bulkhead fitting limits the flow and keeps the water pressure up inside the powerhead. W/ just the hose, you're probably losing a little pressure.
And thanks again ezeke. I added the fitting to the write-up.
Still evolving.
ezeke
See if you can get our Monday morning catch in there somehow. That's my brother-in-law, Joe O'connell, holding a 42 inch striped bass that came aboard at 7:00.:)
iwombat
Nice, so do you tap the outlet hole right on top of the port gill?
ezeke
Exactly- don't you just love irrelevance?
Actually you put the hole right where this factory one is:
iwombat
Be sure to coat the drill bit with Venezuelan Beaver Cheese to catch any gill rakers that fly off in the process.
HighTrim
If you want pics from a V6 i could mail you mine with parts list. I dont want to know what Venezuelan Beaver cheese is, lol ;) Nice catch Ezeke!!
iwombat
More pix - more better.
I may or may not use them, but some choice is better than none.
DavidD
My engine is a 69 Evinrude 85HP. I'd imagine from reading this thread the red circle in the picture would be a place to add a tell tale?
iwombat
Sure looks that way.
Wonder if that plug is already the right size. Maybe it was used for a water-pressure gauge.
DavidD
I just wunder if it will come out.......
Status
