muskyfins
Thread starter- Joined
- Jun 7, 2012
- 587
Planning on adding a stereo amp with a 40 amp built in fuse. I suck at electrical ,but peak output power is 94 watts x 4 channels, so 376 watts/12.5= 30 amp draw. Sound right?
Ok, then per the following chart, and about a 20 foot run from the battery switch to distribution block, I need to use 6 gauge wire. How do we all feel about using the distribution block/fuse panel with a 30 amp circuit max? (below) Is it too small on wire size? Seems like I'm right at the max, but I don't expect to push the amp very hard. Or do I go with a buss bar first and either the fuse panel or in-line fuse the amp? PS-I also plan on putting my power anchor on the same fuse panel, but can't see the stereo and the power anchor being used at the same time. As always any thoughts are appreciated.
http://www.iboats.com/Screw-Termina...0148692--session_id.988318770--view_id.163740
