I have a question about the setup that Bonus diagramed so well with the switch and Blue Sea isolator/combiner. Assuming a welded aluminum boat with a floating ground (ground cable from outboard connected to negative battery post, then bow mounted grounding block connected to battery, and all devices islolated from hull with plastic mounting plates/washers) how would one do the ground connections when adding a second battery as per Bonus's diagram. Would the ground from the outboard go to the starting battery then daisy chain to the second battery? Or would this screw up the isolator/combiner? Would you have to ensure that the feed to the house grounding block came off the house battery and the ignition ground went to the starting battery or would it not matter as they are daisy chained?
Also I'm trying to do this with a 115 Merc Opti with a 60 amp alernator. I see the Deep Blue isolator/combiner is rated for 120 amps so can handle the load but I never saw any responses about the issue of putting a switch between an EFI outboard and the starting battery..... is this a problem or not?
Who ever thought adding a second battery was going to require a electrical engineering degree
