mr300z87
- Joined
- Sep 15, 2010
- 698
Hi all I am getting ready to put my boat in the water for a month long stay at my friends dock behind his house, in brick NJ (IE salt water). My boat has been trialer all it life has no bottom paint (I will proably pull her out after 2 weeks to clean the bottom and I plan to use her frequently), The bigger concern I have in protecting the EXPENSIVE to replace/repair Bravo drive and I will be adding an B1 Anode kit. The prop bearing carrier is already had an anode (not original drive) but the trim rams did not and have no screw holes for the anodes. Can I just carefully drill 2 hole in the ram cap and tap them to the required 10-32 threads? I am guessing that at some point the ram caps were drilled and tapped from the factory. The rams on my project Sea Ray had anodes so I can measure the depth and mark the drill. If this is not do able what are my other options. As always I appreciate any advice.
