I just replaced the engine in my boat with a Mercruiser 5.7 V8 Alpha1 Gen1. The original engine was a V6. I don't know the size.<br /> I am thinking now that the engine is bigger, it will be giving off more heat in the same amount if space that the V6 was in. To help remove the heat in the engine compartment, I wanted to add more ventilation. There are two side vents 17"x 2 1/2" on the outsides of the boat at the stern. I want to buy two cowl vents, and place them on top of the transom, somewhere above the engine with the openings of the cowl vents facing the back to draw the heat out as I am underway. Would this be a good idea? Would this help?
