Adding Power T&T
Slojoe
I want to convert a manual lift 1983 Johnson 70hp to pt/t. Does the oem pt/t unit bolt right into the manual-style transom bracket, or is the transom bracket different for pt/t? If the bracket is different, is the exhaust housing also different?
Thanks
ezeke
Re: Adding Power T&T
PT&T kit #0173827 should have everything you need to add the PT&T to your motor.
