Adding temp gauge to Yamaha 115 2stroke 1998
Eddie Ray
What is the easiest way to add a temp gauge to this engine? Do they make one that can use the same type sensors as on the temp warning buzzer? That seems like it would be very easy to do.
Just thought I'd like to add one .
Thanks
Eddie
Bamaman1
Re: Adding temp gauge to Yamaha 115 2stroke 1998
Most on people would add a water pressure gauge on a 2 stroke before a temperature gauge. Your engine's monitoring system will throw up a buzzer if there is a problem with overheating.
I'd just go ahead and change the thermostats anyway--due to the age of the motor. You'll be good to go for a long time then.
