additional fuel tank
pgpg5860
I'm looking for some advice on installing an additional fuel tank on a 2005 Bayliner 242, I noticed that there is quite a bit of room on the port side of the engine compartment. Any ideas would be greatly appreciated.
Re: additional fuel tank
You need to be concerned about the side-to-side balance of the boat, if you install a fuel tank that is not centered in the hull. You will also want a mechanical brass/bronze "selector" valve to select the new tank or the old tank. A "Y" fitting will not work. You also need to install the thru hull fill and vent fittings, and ground the tank. What about a gauge? You can wire your current dash-mounted gauge thru a selector switch(SPDT Switch), so you can choose which tank you are monitoring.
Hope it helps....
