Adjust all 3 carbs at once or seperate ?
i have an 85 hp force 1989, just rebuilt carbs and set at 1 full turn. it runs ok but i would like better throttle response. should i adjust the carbs separate or in sync with each other
jimmbo
You have to adjust each individually, for best Idle, in gear. It will take several rounds. If one carb is a lot different than the other 2, then checks for Air Leaks, or High Fuel Level in the Carb. After you get that squared away, you can see how the engine responds to Throttle, again in gear. If there is a Bog, try enrichening all the carbs by 1/8 turn and retry. You may have repeat that as well.
I actually would start at a High Idle in Gear, and would adjust of highest speed(ears are very good at detecting speed changes), then I would do the Adjustments at low Idle, as mentioned above
Ahhh in gear, never thought of adjusting that way. thanks man ill give it shot
jerryjerry05
You can set it anyway you like.
Then do the starting fluid test: spray around the intake side and if the spray makes any difference?? Fix it as an air leak can kill your motor.
THEN!! it needs to be fine tuned in the water and in gear.
