Walleye Boat Jim
- Joined
- Jun 4, 2016
- 2
I just upgraded to a 2015 20 HP Mercury long shaft tiller with power start and trim on my 2014 Lowe 1467 WT with a 20" transom. I bought the motor used and it didn't come with any manuals. The motor came off of a similar sized boat and I probably incorrectly assumed it would work properly on my boat. I've had it in the water a couple of times and have had problems with the engine throwing water over the transom. I checked the alignment of the cavitation plate with the bottom of the boat and discovered that the plate was angled a bit down at the rear - the motor being tilted too close to the transom. I moved the tilt stops out one hole and the cavitation plate now looks level with the bottom of the boat. There are five adjustment holes for the tilt stops and mine is now in the middle hole. Since this is a common combination could someone who has this combination confirm that I now have it right? The engine also came with 9 pitch and 10 pitch props. I was running the 9 pitch prop when I did my trial runs. Any comments or recomendations on what prop to run? Thanks in advance for the help!
