Adjusting carb screw
9675hpforce
i have only one carb on this year motor. Is the adj screw only for idle? Is the high speed non adj jet?
scotiany
Re: Adjusting carb screw
On Chrysler engines with Tillotson carbs, the idle screw is for idle mixture-not rpm. Rpm is adjusted by a screw on the tower shaft. This may be similar to your force setup.
