Re: Adjusting Controls
In neutral, the beveled stop IS supposed to hit the interlock plate. When you disable the shift for fast idle, it stops throttle before too much rpm is asked for. (limits fast idle to about 1500-2000 RPM) Otherwise, you could over-rev the engine in neutral. (this is a safety feature that no automobile has.)
When shift is enabled, because of the spring loaded throttle cable, the shift will move before throttle starts to advance. the interlock lever will move either down for forward or up for reverse and NOW the tower stop will clear it, enabling throttle and timing to advance.
In neutral, when properly adjusted, the interlock plate should ALWAYS be even with the tower stop. Since the plate moves the upper shift rod, it should be the rod that you adjust--not the interlock plate. (assuming the plate is properly positioned.) I said in question 3 that it would prevent the shift from moving. That is misleading! The control box lever prevents the shift from moving when you either press the center rubber covered button or pull out the whole handle about 1/4 inch. (depending on control box type) This disengages the shift mechanism inside the control box and allows only throttle advance.The throttle (tower) can only advance slightly because of the two interlock plates contacting each other. This is built into the engine and is not adjustable. (well, not easily adjustable)
Also, remember that because of compliance in the control cables, sometimes the system will not return to a centered neutral. It is sometimes necessary to cycle the control from forward to reverse and back to neutral several times to get it to center.
The bottom shift rod will not tell you anything. It is supposed to be screwed all the way in (clockwise) and then backed out only enough to line up the holes. If it is not screwed all the way in, then the shift linkage would be too long.
If the drive dogs are not ckicking when the prop is spun in both directions in neutral, then based upon your answers to the questions, your shift linkage IS or APPEARS TO BE properly adjusted.
At this point I would recommend looking at other areas for the problem.
Is the regular idle between 700-750 RPM in gear in the water?
Are the choke plates closing fully during a choked start?
Are the plugs clean and are all of them firing? These engines will start and run with one plug not firing. And because of the ignition type, a plug that does not fire at start or idle may fire at high speed. Thus: the engine will run really crappy at the dock yet well out on the water.
Is compression relatively equal on all cylinders?
