Adjusting idle on EFI 4 stroke
bensonr
I have a 2004 Mercury 40 horse power 4 stroke (three cylinder) with EFI. The tag on the motor states an idle speed of 775 rpm in gear. Mine idles at 1000 rpm. I had the tach checked out and it is correct. I've had three technicians tell me it cannot be adjusted, yet I have read somewhere that you can file a brass throttle stop or drill a hole in the plastic to access an idle adjust screw. After looking at some diagrams, it appears to me that this adjusting screw and brass stop are the same part, and that it could be accessed by drilling a hole in an emboss on the plastic intake manifold. Has anyone out there tried this and does it work?
achris
More fish than mountain goat
Re: Adjusting idle on EFI 4 stroke
Hello Bensonr and :welcome: to iBoats.
Idle speed is controlled by the ECM and the Idle Air Control valve. The plate in the throttle body should be fully closed at idle. Just check to make sure it is. If it shows any signs of being slightly open, then check your throttle cable adjustment. If it is fully closed and you're still idling high, suspect the IAC is not functioning properly. Pull it out and check that too...
BTW, there is no idle adjusting screws on EFIs. Idle mixture and idle speed are controlled solely by the ECM...
Chris.....
bensonr
Thank you for the info. I've had no luck so far finding a dealer that can do this for me. I will make more phone calls this weekend.
achris
Just got home from a club meeting, and while I was at the meeting I was thinking about your problem (shows how interesting the meeting was!).... You could try one thing, nice and easy, and will give us some ideas. While the engine is idling, unplug the IAC valve. If the valve is working properly, the engine will stall. If it doesn't change speed, change the valve....
Chris........
bensonr
Do you mean unplug the electrical connector or the air tube? Also, the AIC has two air ports on it, my air tube is plugged into the bottom port with nothing on the top port. Is this correct?
achris
Is this a 3 cylinder or a 4? You wouldn't have the engine serial number handy would you?
achris
Unplug the electrical connector. Only one port connected is correct....
bensonr
Three cylinder. OT868428. Which port is left open, upper or lower?
achris
It doesn't actually matter. That solenoid allows air to be drawn into the intake, and it's used to control the idle speed by the amount that solenoid lets in...
bensonr
I let the motor warm up, unplugged the electrical connection, idle stayed at 1000 rpm. I unplugged the air line, the motor died. When I slowly removed the airline, the motor ramped up to 3000 rpm. I then covered the intake manifold port with my finger, the motor dropped down to 1000 rpm. It seems like the throttle blade is not shutting all the way, but when I unhook the throttle linkage and hold the throttle against the brass stop, the motor idles at 1000 rpm.
achris
Here's the benefit of having a scan tool. Or the disadvantage of not having it. Now we need to check the TPS (Throttle position sensor). With a scan tool you can read the adjustment directly, but we are going to have to do it the old way, with a multimeter.
The TPS is located on the throttle body, attached to the throttle shaft. It has 3 wires going to it, purple/yellow, black/orange and white/lt blue. With a multimeter, measure the voltage (with respect to the engine ground) on each wire.
Chris..
Faztbullet
Make sure engine is in water or test tank as it will idle higher on a hose....
bensonr
I am hoping to check this out on Monday. Thanks for helping me with this issue.
Ron
achris
Ron
Ok.. See you later-Ron... Sorry, couldn't help it... :facepalm:
bensonr
I've been really busy and haven't had time to work on it. It may have to wait until spring. I will probably repost then. Thanks again for your time. Ron.
joeyd0315
Chris.....
hi there, i have a similar issue. what is the "plate" in the throttle body?
thx
Joe
matt167
Racing idle could be a leak at the throttle body. Or an IAC stuck open
chanders
The idle speed on this engine is ultimately electronically controlled. There are 2 throttle valves on this engine, the main throttle body, and what is called an IAC valve. IAC stands for Idle Air Control. Click this link for a diagram - https://www.mercruiserparts.com/bam/subassembly/32557/11848/30 In the diagram locate #21 (It's down towards the bottom of the picture). #21 is the IAC. The way it works is when you are at idle speeds, the engines computer will open up the IAC valve and allow air to enter the engine via the IAC. As you start to throttle up, what you are doing is opening up the main throttle body. As the throttle body opens up, the IAC will start to close. Once you get to about 1500 RPMS, the IAC will be fully closed, and all air enters via the main throttle body. When you throttle back, the main throttle body closes, and the IAC will open up. Because the IAC is an electrically operated air valve, they are considered a wear and tear item, and they do eventually fail. When they fail they will fail in 1 of 2 ways. The IAC will either stick closed, and the engine will not idle at all. Or they stick open, and the engine idles high. All you need to do here is just check and make sure that the main throttle valve isn't sticking open for any reason (like a hung up cable or corrosion). Other than that, if the main throttle valve is opening and closing properly, then you would be looking at a bad IAC valve. Does that all make sense to you. I do want to make sure you are happy with my service before you go. If you had a further or more specific question on the issue by all means feel free to ask. If not, Just in case you do not understand the way the website works (and some folks do not). You do have to put forth a positive rating in order for it to credit me for helping you. When ratings are not done, the website simply keeps your deposit and they will not credit me. The ratings box is located at the top of the screen. To rate, you must select the star you wish and also confirm it. Please let me know if you run into any problems or errors when trying to do it. If you do have a problem, or if you can not see the ratings box which is at the top of the screen. Please reply back "I rate Jason's service _______" and fill in the blank.
Questions do not close out, so if you have to come back later on with follow up questions to the issue you still can even after doing a rating.
