pantaloonz
- Joined
- Nov 28, 2014
- 237
Yes, the boot took a detour today and skidded along the highway and off the shoulder.
My buddy was towing it, the winch strap strapped, and *I did not have the saftey hitch latched-- shame on me*
No one was hurt, and the boat slid harmlessly off the road.
I want to thank the 15 strangers who pulled over and helped me and my friend MANHANDLE that boat back on the trailer. Amazing Human Teamwork!
Anyway it appears to have skid right along the keel and a slightly kiltered to the right. It peeled the paint and probably a few layerd of fiberglass. Though I can see no holes or major gashes or anything indicated the hull was penetrated (except for a small hole I found unrelated to today)
Here's the Bow and gashes along the keel: all of wish are not wide or particularly deep.
This is before I did any work. Here is the worst part, the stern under the drain and you can see the underside of my draink where the pavement shaved it quite nicely.. though it does appear still miraculously sealed..
I've gone ahead and sanded the entire damaged areas from bow to stern. Course grit, wipe down, fine grit wipe down (done with elecrtic sander and by hand) The cleaned with denatured alcohol.
I went ahead and applied a thin coat of resin over all the damage. It's already much much better.
Now the questions:
Obviously I'm not going to be able to easily apply fiberglass to the hull..
I have a little bit of fiberglass experience, I fiberglassed the replacement engine box recently, I used some pretty cheap fiberglass matt as I had strads of it going everywhere. But I understand how to use it and I have the gloves, mask, and all that..
1. The structure of the boat is surprisingly whole... should I have it professionally evaluated? I see no stress cracks or anything..besides the skid marks.
2. Is applying new fiberglass the best bet here? : If so
A. What is the best mat I should use
B. I have standard resion/hardener from my local home depot, should I go differnet?
3. Would several layers of resin be more appropriate?
4. Drain plug? Pry if off and replace or resin/glass around it?
5. Do it myself.. or leave it to te pros?
6. what kind of paint/primer?
I will be redoing the winch and verifying all safety mechanisms. and rest assured.. I will NEVER forget the safety chain agian..
--P.S. 3 of 12 gents that stopped...did so because the same happened to them :0
-Pantz
Now the questions:
-Pantz
