Advice Needed
will941s
I am installing a fuel/water seperator for my 98' merc 25, 2-stroke and was wondering do I put my primer bulb on the gas tank side or the engine side? Also, it's a 10 micron filter and will that allow the oil to flow freely with the gas, or will it filter the oil out of the gas? Thoughts??
mciaio
Re: Advice Needed
Bulb has to be on the gas tank side so it pushes fuel through the filter, rather than pulling it through. I don't know about the oil question.
seabob4
Re: Advice Needed
Wrong. Primer bulb goes between fuel/water separator and motor. Keeps the crap out of the bulb.
Rocky_Road
Re: Advice Needed
The 10 micron filter element will NOT affect the oil/gas mixture.
will941s
Re: Advice Needed
Thanks for the replies. I will intall the kit tomorrow and hit the water.
gss036
Re: Advice Needed
For what it is worth, I agree with seabob4's. That is the way mine had been for kicker and main motor for the past 20+ years.
Dhadley
Re: Advice Needed
Actually neither location is "wrong". Here's the deal - primer bulbs are better pushers than pullers. Sooooo...in theory that means they need to be located as close to the tank (fuel supply). But, as stated (correctly), if placed after the filter there's a good chance they'll not get contaminated as easily. With some boats (like mine) there is no way to get the primer bulb anywhere near the tank.
The 10 micron filter is the prefered filter with the government fuel we're getting.
will941s
Re: Advice Needed
Installed it, ran it, does great. I put the bulb on the engine side, and I think on the 4th pump it filled the line.....with a empty dry filter starting off. Thank for the help.
