Re: Advice on Changing Pump Impeller Please
It is not bad at all, just looks challenging till you’ve done it once. I am not a mechanic and I just did one in the dark with only car headlights and a flashlight. The manual you bought should help you through. Lots of good stuff on this forum use the search button. On a 1- 10 scale 1 being putting gas in the tank and 10 a full rebuild, I’d say this is a 3.<br /><br />All you have to do is:<br />1. Be patient and use your head.<br />2. Remove all the bolts, there is one hidden under the steering trim. <br />3. Remove shift linkage rod connection on that motor I believe it is fairly easy just pull a cotter pin and push in the linkage.<br />4. Observe how the water pump key is oriented on your shaft<br />5. Clean old gaskets and gunk before reassemble<br />6. Don’t mess the shift rod length<br />7. Reassemble and test<br /><br />Did you buy just the impeller or the kit with the metal pump housing too? <br />Mac
