Re: advice on rebuilding 9 1/2 carburator
Edit: Guessing "oil plug in the bottom" means lower unit fill plug.
The lower unit oil you should change if you haven't already. The procedure is as follows:
Remove lower plug drain plug, then remove upper relief plug and let it drain.
Fill the LU through the lower hole until lube comes out the top hole. Insert the top relief plug, remove lube spout, insert lower plug.
Make sure to use fresh seals on the plugs _every time_. Buy a half dozen at a time and remember where you put them.
For that carb - carb cleaner and compressed air if you have it. Make sure to get all the little nooks and crannys, spray through every orifice and make sure it comes out someplace else.
