I_5320
Thread starter- Joined
- Jan 3, 2011
- 59
Hey All,
Having a mental block on the best order of events. Hoping to draw on some experience to get me through my project
In reading the threads I'm getting most the education needed on the individual steps but any advice on a different order or anything key I may have missed would be appreciated.
Boat: 1985 16 Sylvan Alum
Resources: Heated Garage 1 1/2 bay
Project : Only putting floors, pedestal seats, interior side panels, painting and mounting a tiller motor
I bought it gutted and never had the boat in water.
Hull condition seems to be good but need to plug live-well intake(fitting is gone and only have 1" raw hole) and side drain.
I've pulled and built a new transom, drilled my oversize and it's all Expox'd up. (Standard Iboat Forum specs)
So this is where I'm stuck,, It's Feb here in N IL.
Here are my thoughts.
1. Plug/Fix my known holes and do a water test by filling with 4-6 in water and see if she leaks. (Is this adequate???)
1a Fix rivets and or any leaks found
2. Install Transom to give rear end is structural stability, and flip for paint prep.
2a. I plan on making boat dolly to free up trailer.
3. Inspect Trailer hardware Rollers and bunk boards if needed. Replace bearings and bearing buddy's regardless . Paint Trailer.
3. Prep, prep, prep and Paint boat (Plan on following Woodonglass's Roll & Roll or Spray with Valspar)
4. Flip bacK
5. Install floatation material. (Got to be noodles)
6. Install flooring with extra structure for pedestal seats. (Will use standard Iboats recommendation Epoxy all and Exterior paint for topside)
7 Rough out interior.
8. Wiring for all electronics with Switch console
9, Finish out interior
10. Install Motor and put her in the water.
4. Flip bacK
