Re: Advice please! Fiberglass boat hull hole patch (pics)
Thats a lot of air trapped in there..do you have some better pics of the Inside Final lams please.
Outside lams have to be better than that ( get a bubble roller ). You cant do glass with just a Brush !
YD.
After the sheets of fiberglass were laid down and brushed into place, i used an 8" plastic, hardened edge scraper to run the air bubbles out of the the layering. I did this as each layer was being laid in place.
One of you mentioned using a roller, what type of roller exactly are you talking about, resins and select rollers will certainly not cooperate well together. I feel like with the 8" hardened edge of the plastic scraper, that i was able to chase most all of the air out between the layers and obtain the best bond i could without some sort of vacuum system being used.
There were two very minute spots that i was concerned about after the cure that were noticeably, slightly raised. They were both about the size of a quarter. I grinded down through that one top layer, opening up this concerned area, sanded the edges of this new area and will be laying on top of it to strengthen it all.
I still have to put a few more layers in here then moving on the stringer repair.
What type of roller would you suggest to squeegee out the air between the layers, i just cannot envision a napped roller creating enough surface tension to move the air as the scraper is able to generate.
However, i certainly do not know everything and I am sure there may be one specifically designed for this job that i am not aware of, please advise.
Chris
