Advice upgrading trim pump
strombolichef
Hello I have an older system that uses external reverse lock. That erl is leaking oil. what newer type pump should I get to eliminate the erl and how do I install the hoses of the new one. Many thanks.
Re: Advice upgrading trim pump
Ayuh,... You can use the newest style of pump, 'n you'll need to delete All of the reverse lock, 'n go with New lines, from the manifold on the transom housin', to the pump...
