Demolitron
Thread starter- Joined
- Sep 17, 2007
- 32
Hello,
I'm looking at a boat powered with a 1989 Mercruiser 3.7L Alpha One Powertrim XD. It is a 1989 Wellcraft 180 classic hull. The owner says he can see the serial # plate but can not read it. I am going to look at it on Saturday to see for myself.
He says that the boat hasn't been on the lake in 10 years. It was not fogged before storage, but has been covered indoors for that time. The fuel tank was not empty when stored.
I was going to go there with a tool set, a battery, and some testers to evaluate the engine.
First I would remove the plugs and fuel line. Then spray in some penetrating oil, like MMO, and try and turn it over using a breaker bar on the crank pulley to see if it was seized. Then try the starter using my fresh battery and go for a compression test. I assume the impeller is trash so if I don't hook up to the hose could I do more damage?
Also, are they telltale signs that the manifolds/risers are corroded/shot? Can I tap on them and listen for a particular sound, or look for the presence of corrosion at the mating surfaces?
I assume that I'll need to replace all the transom rubber after all this time has gone by. I also assume, because of the fuel varnishing after 10 years, that I'll need to rebuild/clean the carburetor, replace the fuel tank, filter, water/fuel separator, and lines. (Or is there a way to clean these out?) Would it also be likely that I'll need to replace the fuel pump, or can I rebuild it with a kit?
Regarding the engine coupler, if the motor did settle/shift could it deform the engine coupler after all this time. I've read that the engine alignment should be done every time the drive if off. Which seems that would normally happen every one to two years. Could the rubber in the coupler degrade after all this time and need replacing?
I am trying to be pessimistic about this so I don't get too surprised if I buy this boat and need to replace and repair a lot before I can get it on the lake. I am mechanically inclined having rebuild import auto engines before, and I have replaced the gears/bearings in and resealed the lower unit on my outboard.
Thanks for your time.
