bigskiohio
Master Chief Petty Officer
- Joined
- May 3, 2008
- 882
Re: Afraid of the water
just look at the choke. takes a minute while running .
So I .....stuck my hose into one side of the exhaust tubes coming out of the back of the boat ...I also pinched the opposite side shut with a pair of vise grips. I did this to try and simulate the boat being submerged. And the boat would not start. It took about a minute for the boat to start.
When I purchased the boat it had a cracked block and head due to incorrect winterization.
I am thinking there is a good likelihood that he also cracked the exhaust manifolds and water is getting somewhere bad.
What tests can I do to verify this?
...now I beleive you're getting somewhere!!!
Your garden hose simulation, combined with the fact that the head and block have been changed out, leads me to believe that you either have an incorrect gasket in the riser and/or a crack in the exhaust manifold.
I am certain that Don S. can straighten you out on the correct gasket(s) and manifold tests.
FWIW....Ed in 'ol Virginny
