stephentyler20
- Joined
- Apr 13, 2008
- 117
On my Alpha Drive (previously posted on the subject but not w/r/t overheating - this is "new"). Basically, it was stuck in mud/debris to the point where my Dad managed to shred the prop trying to get out, instead of shutting down (ugh).
I went through everything last week, replaced the prop, changed all oil, inspected everything, etc. Boat runs fine, but overheats at LOW speeds and idle - raising the engine speed drops the temp. It doesn't overheat quickly, but after 5-10 minutes idle at the dock it crept up towards 200 so I shut it down.
What I've done already: ran it on the muffs, changed the water pump (full kit w/ impeller), changed the T-stat.
None of that fixed the issue. Where do I go from here? Specifically, I'm hoping to keep it in the water for any additional repairs - it's a huge pain in the neck for me to trailer it back out, and I've already done it twice in the past 2 weeks. If it really needs to come out of the water, chances are it will have to stay out for the season, and that would suck!
I'm not sure what else to do, but my understanding is that if I just pull the T-stat altogether it should run cool, so that may be an attractive/easy option. Would love some advice though!
