sutor623
Thread starter- Joined
- May 23, 2011
- 4,089
A couple months back I put a set of CDI ignition coils on my 130 looper. First trip out I dropped spark on #3 cylinder. Got home, swapped coil out with known good (used OMC) one, problem solved. I sent the bad coil to CDI and they sent me a new one. Got the new one, swapped it back out with the Evinrude coil. Next run went to the water, after about an hour run time I dropped spark on a cylinder AGAIN!! This time it was cylinder #4. Swapped the CDI coil out with brand new Evinrude coil. and back on the water, no issues.
So, I have had 2 CDI ignition coils fail me after only 1-2 hours of run time. Should I just swap the rest of them out with new Erude coils? I know one thing. I will always have an extra ignition coil or two on the boat from now on!!!
