Aftermarket starter for 90 ELPTO
dandreye
Hi All,
Looking for a spare starter (#50-66015T1) and seeing 3-4 times price difference between OEM and aftermarket ones. Are the latter ones that much worse? Which aftermarket makes are the best and which ones should I stay away from?
Thanks in advance,
Dmitriy
wired247
Re: Aftermarket starter for 90 ELPTO
Ive used a fw aftermarket starters and the drive gears spun off both of them. I would rebuild a used factory starter before I'd buy another aftermarket.
dandreye
wired247:
Would you prefer a used OEM one over a brand-new aftermarket one then?
I just need a spare one as time during the season is too precious: this way I can have the current one rebuilt at any moment w/o any sacrifice.
wired247
If it works, and they are pretty reliable, I would go with a used Merc starter over a new aftermarket. My experience with the aftermarket ones has been pretty dismal.
$20 for a set of brushes for a used one .
dandreye
That's what I'm saying: OEM ones are $200 or more while aftermarket ones start at $50-60.
I saw a used OEM one reportedly in good condition selling just for $25 yesterday - might go for that one.
bruceb58
List price on an OEM starter is $700. These are bargains.
A used $25 starter may be no bargain in the end.
wired247
Its a starter. $20 worth of brrushes and a cleaned up Bendix. Voila ...new starter
Excessive cranking burns these straters up all the time.--When you hook a bad one up to a battery it will crank.----Will it turn the motor over fast enuff for instant startup ?---Don't think so.
dandreye
I've ended up buying that used OEM one for $25 after they confirmed they had checked it when cranking the engine with it to test compression.
Thanks everyone for your replies!
