Air cleaner for 1996 Merc Carb 2 barrel...
rhillman75
I am looking for an aftermarket solution to my 1996 Merc Carb 2 barrel. My top plastic cover is cracked and the Mercruiser air cleaner is suffering from dents, dings, and a little corrosion. I know there is an aftermarket solution out there, but after searching for "air cleaner for merc carb 2 barrel" on the net, all I find is the problems with this car that everyone encounters. Any thoughts or links would be great!
Don S
Re: Air cleaner for 1996 Merc Carb 2 barrel...
It's called a flame arrestor, not an air cleaner. The plastic cover is just that a plastic cover, and you aren't going to find it as aftermarket.
Go to the link below and type in your serial number and you can get the OEM part numbers for the parts.
https://webapps.brunswick.com/literature/literatureSearch.do
