hungupthespikes
Master Chief Petty Officer
- Joined
- Sep 25, 2009
- 814
Re: Air lines for Shop
Got curious about PEX so here you go.
Not good numbers for compressed air applications, yea I know they are for hydro not air
What temperature and pressure ratings does Uponor PEX carry?
Uponor PEX carries the following hydrostatic temperature and pressure ratings:
? 200?F at 80 psi (93.3?C at 5.51 bar)
? 180?F at 100 psi (82.2?C at 6.89 bar)
? 120?F at 130 psi (49?C at 9 bar) (?" Uponor AquaPEX? tubing only)
? 73.4?F at 160 psi (23?C at 11 bar)
Just found this: ( near the end)
http://www.uponor-qe.com/wp-content/uploads/2013/03/Specification-PEX.pdf
UPONOR PEX should not be used for
Natural gas
compressed air
heating oil
swimming pool
There are several grades of PEX so if your going to use it be carful to find one that is rated for the application.
As biggee and myself said it is used in industry, but your going to have to Google to find a supplier that carries the right grade.
I found several manufactures of PEX type products that can be used for compressed air. :whoo:
Let us know how it comes out.
huts
Originally Posted by hungupthespikes
I'd run a piece of PEX from the compressor to the start of the pipe so the noise/vibration of the motor could be controlled a little better.
Natural gas
compressed air
heating oil
swimming pool
huts
