MH Hawker
Thread starter- Joined
- Jul 13, 2011
- 5,516
Being as its been slow lately I thought I would ask about this.
Over last winter I converted my 1996 9.9 hp 0G119661 to a 15 hp and it has worked very well and I have put a bit over 80 hours on the motor and the only issue is a WOT RPM thing, the motor runs between 5400 and 5600, and it will just up and down a bit, I tested the tach, and went over the fuel system, and pulled the plugs for a inspection and that may be my first clue. The plugs were in very good shape but it appears it is a touch lean they are a very light gray, the outer shell was black with carbon so I turned up the mixture screw a 1/4 turn and that seamed to fix the RPM fluctuation or at least improved it.
I was wondering how much effect the air mixture screw has on top end performance. I had thought it was mostly at low RPMs.
