Do I need them? Is it a big deal if I run without them? Will the motor run lean? Its a '79 140 Seahorse.
The reason I'm asking is that I replaced the fuel lines and I can't figure out how to get the Silencer extensions on without kinking the fuel lines. I had them installed correctly then I needed to remove the carb do to something stuck in the float valve. When we reinstalled the carbs we kinked the fuel line, now I can't figure out how to get them back without kinking them.
