air silensore cover box
iwombat
Re: air silensore cover box
. . . and don't forget to factor in any offset from a non-centered timing pointer.
i.e. If the pointer is about 2-degrees to the left of centered factor that in.
canman
hi all . i got a hold of the mechanic he wants to take a look at the motor again . i will let you know what he says thanks .
Walker
As per OMC Manual. Idle timing 8 ATDC, if idle is too slow timing may be adjusted to 6ATC
Max advance 18 +/- 1 degree BTDC
Dhadley
Remember, this is a 1985, not an 86 or later.
