mississippiriverrat
- Joined
- May 12, 2007
- 9
new to iboats and boating. wanted to say you guys are great and i have learned a lot just by reading in the forums. I bought a used mercury out board ser. # OB383808 it is suposed to be a 200 hp black max went through cooling system and replaced the thermostats popit valve and water pump rebuilt carbs and changed lube in lower unit. but i am still getting a over heat alarm when running above a good fast idol. pressure gauge seems to be working right 5 to 8 psi at idol and goes up to about 18 psi at 2800 then drops after popit opens pulled sending units on the heads but need to know if these are both overheat alarms or is one for the temp gauge both have airpac on them but differnt numbers one is 9751 and the other is 9919. they are both wired to the same terminal block and go to the alarm horn. is this right or is there something wired wrong i got a manuel from libiary but could not make heads or tails from the wiring charts. would like to get this fixed the cats are starting to bite
