Alarm going off
dc_1996
Hello I am new to this forum and I just ran into a problem with my motor this weekend during a tournament. I have a Johnson/evenrude 1998 faststrike fitch. I was going back to the ramp for chackin and about halfway back my alarm went off and it was a lost constant alarm that went on for 10 seconds of so. I went to an idle and the check engine light was on but the loud alarm stopped. I got the manual out and it stated that fuel restriction and overheating makes this sound. It also stated it overheating, egine would kick down to low rpm and it did not do this. I checked the fuel bulb and it was not tight so I squeezed bulb until tight. After ten minutes i fired back up and was on my way and the alarm went off but was running fine back to the ramp. Oh by the way did check water pee and was fine. The next day take off was fine until about 4 miutes full throdle and loud constant sound and light came back on. This did this througout the day. The light would turn off at full throddle and then a few minutes it would come back on. Can someone give me some abvise to my next steps!!<br /><br />David
gpetrilak
Re: Alarm going off
I am no expert on Ficht's but have had many an alarm on mine in the last 3 years. From what I have gathered if the engine doesn't go into slow mode and the light isn't flashing, a fault was detected and should be checked. Should be safe to run back to the dock. Get a service tech. to read out the alarm codes to see what is going on. <br /><br />Some things that cause this are water in fuel, throttle position sensor, hi / low engine temp, hi / low voltage.
papasmurf
Re: Alarm going off
You need to get with someone who has the proper software for this motor and knows how to use it. The motor will store a diagnostic code in the EMM/ECU and can be retrieved with this software.
horsefly38425
Re: Alarm going off
Welcome dc, I have a 99/ficth,mod# e175fpleec that is got me about to go nuts with this same thing. I took it to a high dollar racing tech. And he replaced my thottle position sensor/500$ said that was it :mad. It did it frist time i went out,took it back and he adjusted thottle cable/said he reset ecm /same thing agin it comes on then goes off somtimes a minute or 2/ may stay off a while 5/10 min and it does it agin.A friend of mine has one and tells me if i continue to run it I will hurt somthing that is big$$$$ :confused: .Maybe we can find some help here. I am starting to think my ficth is a wicth or worse/maybe I should just cut the buzzer wire :rolleyes:
dc_1996
Re: Alarm going off
Hey horsefly. I have not done anything yet. It is sitting in the garage right now wondering what I need to do next. I have a Evenrude sevice tech down the road and I know it is going to be a arm and a leg, but I need to hook it to a computer to see what its going to say the problem is. Did your check engine light stay on for awhile after the 10 to 20 second constant beep went off? I am trying to gather as much information as posible before I drive it down to the tech..
horsefly38425
Re: Alarm going off
Just tryed mine agin /with engine cold went about 1/2 mile ck eng light came on buzzer came on and it went to idle mode. Stoped eng refired and ran about 1mi same thing. let it set a minute or two /restarted ran fine the rest of the day 24+ miles :confused:
papasmurf
Re: Alarm going off
The software is available on-line. Try BOATSETUP.COM, they deal with alot of Ficht questions. It might be something simple but you need to retrieve the codes.
horsefly38425
Re: Alarm going off
went out today 'i find if i don't run at w/o/t it does not happen.temp/oil is ok so i don't think it can damage the powerhead. BASS tour next wkend guess i'll run just under w/o/t. And go fish/cause the boat shop say's[ throttle positon sensor migth be bad /i think they just don't know what is wrong.
dc_1996
Re: Alarm going off
Got software and reveiwed the code. The code was #37 water in fuel. So I changed the fuel filter canister and cleaned the conection to the water sensor on bottom hooked all back up. Went out yesterday and on the way out running about 4000 RPm on check engine light and buzzer went off. Checked and was code 37 again. What next I just changed the filter. Any ideas!!<br /><br />David
