alarm going off
hipshot007
1990ve90tlesb have beeping alarm going off about every second @ idle after running for just a few min. I have good water discharge heads arent real hot to touch.Could alarm be for something else?like low oil in lower unit?need advice
Joe Reeves
Re: alarm going off
(VRO Horn Warnings)
(J. Reeves)
NOTE: I retired around 1991/92. Possibly some of the later V4 engines and others may also incorporate a fuel vacuum switch that would enable a fuel restriction warning to sound as mentioned below, an unknown factor to myself.
1 - A steady constant beep = Overheating - The V/6 engines, possibly some others, have a fuel restriction warning which is also a steady constant beep.
2 - A beep every 20 or 40 seconds = oil level has dropped to 1/4 tank. (Late model engine = Every 40 seconds)
3 - A beep every other second = VRO failure, air leak in oil line, oil restriction, (anything that would result in a lack of oil being supplied to the engine).
NOTE - If the warning horn is the black plastic (overpriced) three wire type horn, the warning horn should beep once when the ignition key is turned to the ON position. If it does not, it is either faulty or someone has disconnected it (a stupid move!). At any rate, if it does not beep which indicates that the horn is non functional, find out why and do not run the engine until the problem is corrected.
hipshot007
Re: alarm going off
ah that could be it I bypassed vro pump now I mix oil with gas I unpluged wireing for vro system.Could that be causing problem? no more alarm.yea thanks admiral well done
hidef
Re: alarm going off
Did you unplug only the tank and not the VRO pump? The pump under the engine cowl also has wires running into it and needs to disconnected.
hipshot007
Re: alarm going off
yes I did no alarm now.thanks all,now I make a new thred on fast idle 1500 rpm
