Alarm location on my engine?
jacques84legros
Hi,I have a 89 XR2 150 and was wondering if anyone knew the location of
my alarm ?
It does'nt beep ????Could you also tell me what wires on it should have power and which are ground???
Thanks Jacques
Laddies
Banned
Re: Alarm location on my engine?
Depending on the control your horn is suppost to be in the control box or under the dash. The horn should have power when the key is on and the senders are grounds, so if you disconnect the temp sender and ground the wire the horn should blow.
