I have a Volvo 4.3GLA. I spent the day on the water with no problems, oil pressure up, water temp down ect...
When I got home I put on the muffs to flush the engine and as soon as I turned the key to the on position an alarm went
off. With the key on I disconnected one at a time the 4 connectors from its sender. The alarm stopped when I disconnected the wire from the oil sender.
I left the wire off and started the engine to flush it. As I was flushing I reconnected the oil sender wire but there was no alarm. Once finished flushing I turned the engine off and put the key in the on position and the alarm sounded. Is this an indication of a bad sender unit? Oil pressure all day was around 40lbs and the oil level is good.
