capercanuck
- Joined
- Apr 13, 2002
- 78
The alarm on my 350 OMC sounded yesterday after running for approximately 30 minutes. The alarm I'm talking about is the one that tells you if the engine temp, transmission temp or oil pressure gets too high. At the time the engine temp had risen to 180 degrees...a stuck thermostat. The thermostat in it is a 160 degree unit. I took the thermostat out and the temperature dropped dramatically. The oil pressure was at 40 lbs...but when rpm increased the oil pressure increased. I guess this is normal. The alarm still sounded when the boat was running. I had to take my chances to get the boat back in, and it ran really well all the way back to the dock. The alarm sounded all the way in. The oil is full and clean. The belts are tight. There is was no thermostat in the engine, so it was running really cool. What is my next step? How can I track down the source of this problem? I don't know how to tell if the transmission is running hot. Is 40 lbs oil pressure sufficient? Any help is really appreciated!
