I just had a new (used) powerhead installed on 1 of my 1992 150hp Johnson Ocean Pro outboards and.... the motor seeems to be running great. Prior to blowing up the old one I would get an intermittent alarm after throttling up to approx 4000 rpms. I thought that the alarm would go away when I had the powerhead (and oil pump) replaced. Turns out that I still have the alarm with the new powerhead.
I THINK its an over temp alarm. Its continuous and stops when I back down on the throttle and it only happens when I'm in gear. Since I replaced the powerhead I assume that the problem is with one of the pieces I didn't replace. The water pump is putting out what SEEMS like a sufficient stream and the temp gauge on the dash does not indicate an over temp condition....but I still get the alarm and its always comes on between 3500 and 4000 rpm. Could it be the waterpump? This is making me nuts! I've gone through 2 powerheads this year (different motors) if I blow another one I'll probably have to get a new wife and a new hobby.
